How do I cap off the front axle vacuum motor
Hello All,
This is my first post on this site. I have an 1998 F150 that I want to tow four wheels down. The manual states that i need to cap off one side of the front axle vacuum motor. Can someone tell me how to do this? I would also like to know why. The manual also states that the max speed is 55MPH. I was told that ford only put that in for legal reasons and going over 55MPH will not hurt the truck. Can anybody give me info or opinions on this? I normaly drive at 65MPH
Thanks for the help
Les
Thanks for the help
Les
Vacuum line disconnect
Thank you Zaairman,
I do have the manual transfer case. I'm clear on the shifting it into neutral. I'm still not clear on should I plug the vacuum line after I disconnect it or just leave it unpluged? It looks like two lines going to the motor/axle so how do I know which one to unplug? It's almost dark here so i could be wrong on the two lines. Is there a way I can comfirm that the front axle is in the position it needs to be for towing?
Zaairman, I know I'm asking a lot of questions & I thank you again for you help
Les
Les
Originally Posted by Zaairman
Yes, there is one line going to each hub, but if its like my Superduty then there is a T connection in between the vacuum pump and the hubs. I'd just unhook the line straight from the vacuum pump.
BOTTOM VIEW
The lines that are cut off are the vacuum supply lines. Mine are all faded out but there is a pink and a blue line. The pink disengages the diff lock and the blue engages it. I guess I would plug the pink one or both to have everything covered.
I see the towing instructions in the manual but I can't figure out why they would want the vacuum lines plugged.
Originally Posted by Lwalston
I asked the question are several sites as to why the Vacuum lines need to be pluged and no one has had an awnser. I will go ahead and plug the line , but I sure would like to know why it has to be done in the first place.
