Make 7-pin plug charge circuit always hot
Got a question that is making me curious. When you turn on the key obviously the trailer charge wire in the plug goes hot, but how can I make this go always hot. The only reason I ask is I'd like to plug in a strobe light to the camper hookup in the truck bed, which is wired to go through the trailer plug in the back of the truck I have.
This is only for one weekends use while doing traffic and parking lot control, is it as simple as getting a different relay or jumping accross the relay in the fuse box? The strobe draws 3 amps when it flashes, so it isn't going to run down my battery for the little bit of time my truck won't be running.
Now I know that the obvious thing here is to plug it into the cig lighter, but I don't want to do that when I have a plug-in so handy and close in the truck bed.
Thanks!
Thanks!
To answer your question as to how to get the auxillery always hot you will need to run a fused wire from your battery to the trailer plug. It is easier to run a temporary wire to your cig lighter...which is a fused source.
The wire you will be tapping into at the trailer plug is the orange (1991-current) or red wire depending on the year of your truck.
Or, now that I have been playing around with my multi-meter, you jump pin 30 to pin 87 and your trailer plug goes +12 all the time. Exactly what I wanted, and the 30 AMP fuse in the box is still in use, the relay sits in the glove box until I reinstall it later.
I used 4 inches of 10 GA wire and two male plugs (if that is what they are called).
Keep in mind this is only for two days use here in a couple weeks. I won't be leaving this jumped all the time, I feel that ford has a reason for doing what they do and relaying the +12V on the harness, therefor the relay has been reinstalled until that event weekend comes about.
![banana](https://www.f150online.com/forums/images/smilies/banana.gif)
