First heavy tow
First heavy tow
Towed the enclosed trailer with the car in it for the first time this weekend. Its a 24ft enclosed and with the car its at least 7500 lbs. Plus another 500lbs in occupants and gear in the truck. I was a little concerned that the truck wouldn't have the umph to get the job done but much to my surprise it performed great.
I was seriously considering having to go to 4.10 rear end but I see no need for it now. The truck pulled great going up hills, maintained 70mph no problem (although I went 60ish most of the way) and really didn't seem to be straining that much at all.
I have an equalizer installed and P3 brake control. Combined they made for a very uneventful tow. Only mods on the truck are AF1 intake and Magnaflow SIDO exhaust. (still waiting to get my xcal to work).
So overall, quite pleased. Gas mileage sucks but I knew that would be the case. I can't be happier with the performance of the truck.
Originally Posted by risupercrewman
With that weight he sure isn't towing with a 4.6, you must be kiddin...
RobertmIII: either way, I am glad to see you use your truck as a truck. these things have the best tow rating in its class, so heres to you!
Just wondering: what gears are you running? the 3.73? Limited Slip?
I'm running 3.55 LS. That's why I was concerned. The tow rating on my truck is 8k because of the diff and the 18" wheel/tire combo. So, I am actually really close to factory limit.
I'll be towing to Savanna in Dec so that will be a better test. The hills get pretty good going through the appellations. I'm still not convinced I won’t need a shorter rear end to ease getting up the bigger hills. 2k miles there and back will be a pretty good work out for her!
2k miles!? now thats a test and a half. And ya that 3.55 will hurt just a bit but the LS should help. You running your truck completely stock? Stock tow package tranny cooler? Either way its an impressive tow and the up-coming 2k will be a mighty test . Might want to think about trany temp guage? (just a thought) And are you doing the gear swap before? or are you going to wait til after?
Originally Posted by MercedesTech
...that 3.55 will hurt just a bit but the LS should help...
If I didn't have 4wd I would have been stuck in the parking lot at a tractor pull thanks to my open diffs. Went to pull out of the pits (dry grass lot) with my 5000lb tractor in tow and just spun helplessly, it didn't even try to move. I pulled the magic lever and never looked back, but if I didn't have that option I would have been looking for a tug or unloading my tractor. A limited slip would have helped alot, and a Detroit TruTrack is on my wish list for my truck. It would also be less likely to break loose from a start up a hill as well, if you are always out on the open road it isn't much of an issue, if you manuver trailers around at slow speeds they can help depending what your terrain is.
P.S. Look at ANY truck comercial. They give you MAX tow capacity... then if you read small print it says must be equiped with tow package 4x2 and have LIMITED SLIP. Also look around, almost every truck dealer sells a tow package and almsot all tow packages have LIMITED SLIP. There may be something to this... Limited slip can help bring your max tow rating up a bit!
