Towing Horses
Towing Horses
Hello all, in a coupld of years I am thinking of buying a couple of horses.And I have a 05 scab with the 5.4, 4x4, and 3.55 ls. I am thinking of putting 4.10s in it. Should I modify this truck any or should I just think of upgrading to a 250 or a 350? Also, what kind of mods should I do?
Thanks,
Chris
Thanks,
Chris
Ok, i have been looking and at the trailers that I have been looking at they have been around 2500lbs, empty. And Im not talking clydesdales, belguims, perchons or a huge horse like that. I can tell you about cows, not horses..lol. So im figuring on a horse to weigh anywhere between 600 and 900 lbs, so that would be 1800lbs on the heavy side with horses So thats 4300lbs, no gear. I should be alright?..at least if my figuring is right.
Chris
Chris
2 horse bumper pull trailer loaded with 2 15-16HH QH's will weigh in at about 5 - 6K lbs fully loaded. Well within the range of your F-150. Have you ever towed livestock before? It's a bit different. Kinda weird when the load your towing gets angry while sitting at a stop light and starts to bump enough to push the truck forwards a bit...
I can only imagine an angry horse kicking the side of the trailer while some lady in her Honda Civic is right next to it... something about that picture makes me laugh as well...
That right there made me laugh...
OK, first, weigh the trailer. Horse trailer manufacturers are virtually always very light in their weight estimates, I've seen them as low as 50% actual.
Second - live load. Margin for error is huge because it can change it's position. The rearing up and removing a bunch of tongue weight is real. As is the reverse. Figure the reality is 2/3 of rated (rated 7,500, you have 5,000# to work with). I know, lots of guys that have never pulled horses will tell you that it's fine to go to the limits. Having clocked over 100,000 miles with horses in various trailers, I would beg to differ. You have to plan for the one time the horse panics over something. Slant trailers can push the limit a little closer than straight loads.
Quarter horses you can figure around 1,000# each plus 200# for gear and feed. Some are lighter, but that's a a safe limit.
You'll be hard pressed to find a two horse trailer with a dressing room that is really inside the capabilities of a 1/2 ton truck (other than max capacity reg cab type set up). Most trailers like this are closer to 4,000# in my experience.
Originally Posted by davenay
Even more exciting is when you are driving 60MPH down the highway and both horses decide (for some reason) to shift all their weight to their back legs, and suddenly transfer 1000lbs from in front of the trailer axle to behind the axle.
Originally Posted by Bryndon
A 3/4 ton is excellent for 2 horses. Lots of people pull with 1/2 tons, but with a dressing room, they are mostly pushing their luck. More a matter of when they'll get in trouble, not if.
Originally Posted by 02XLT4X4
If the trailers he is looking at are 2500 empty plus 2000 for 2 critters that equals 5500, which is well within the relm of a F-150 with a fair amount of gear.
Live loads are not the same as normal loads. Take 2,000#s and start moving it around while you tow.
5500# live load is more like an 8000# load than a 5500# load.
