Weight Dist Bar falling off
It sounds like you don't have something adjusted correctly or there is something broken on your hitch. All the hitches I have ever dealt with have some sort of mechanical device holding the bars in place. Round bars have detents in them to hold them into the hitch head, Trunion bars have to be put in the hitch head a certain way, then they have keepers that must be depressed before it can be removed, Equal-i-zer brand hitches have pins that go through the head and the bars. It sounds like you are missing parts or did not hook up correctly.
I knew the clip was a little loose but when i inspected closer, it was really loose. I had no idea that little thing would make such a big difference.
This is the exact reason I inspect my hitch setup on a regular basis. Things break and wear out. Before I got my Equal-i-zer hitch I had a round bar WD setup. I used to snap the bars into the bottom of the hitch head and let them hang there by themselves. This is a good test of those little clips.
