trailer wiring question.
I have a box trailer with 12 volt interior lights and a battery for the break away system that is charged off the same circuit. Everything works on the trailer except these items which did work on my Chevy. Does the Ford 7 pin plug have a constant hot wire as it should? If so, why is mine not hot and what do I need to do to fix this? Its a real pain having no lights in the trailer. BTW I have a new body style 04 FX4 super cab with the heavy duty tow package and yes I did put in the relay so my trailer brakes work. Thanks
I guess I never tried my interior lights with the ignition switch on. On my Chevy they worked all the time which was nice for when you just wanted to jump in for a second to grab something. Makes sense about not running the battery down when trucks not running but still a bit of a pain if I have to unlock the truck, turn on the key, then walk back to the trailer. I guess I'll have to look into installing a bigger battery on the trailer for this purpose that charges when I'm hauling it down the road. Thanks for the info.
