building a Tow Vehicle
After towing a loaded 12X6 U-haul coast to coast with a 2006 Screw 5.4l 3.55LS with 285/70/17's, I decided to give it some help for the way back. I am swapping gears for Yukon 4.11's this week. I have an order in to Mike Troyer for an AF1 3.5" CAI, Roush SIDO exhaust, and an XCAL3 tuned. I have been looking at transmission and differential covers. I also need something to monitor temps. I still have the stock 30" tires. I'll probably mount those the next time I pull a long trip if it's not to small a diameter for the 4.11's. Any other suggestions?
if you want something to monitor temps take a look at scan gauge II, i just got one and they are pretty awesome. tells you every thing, and is pretty accurate. price is very reasonable !!!
www.scangauge.com
www.scangauge.com
another thing to add would be a good tranny cooler.
I pulled a 8x18 tandem cargo trailer from Wa. state to Fl. trailer weight+cargo= 10,600 lbs.
Oh yeah, and did i mention the mighty 4.6/4R70W done that job for me!
mods for the tow:
-4.10:1 gears(yukon)
-detroit truetrac
-transgo shift kit
-11"x 13" aux tranny cooler-stacked plate design
-New dual core radiator
-Heavy duty fan clutch
-gibson exhaust
-Prodigy brake controller
-Diablo predator
-10,000 lb weight distributing hitch
-hellwig ad a leafs the big ones(2500lb?)
-goofy mirrors that attatched to mine.
Took me 6-7?days, kept speeds about 60 mph, except for those Idaho mountain passes were killer, up around 8000' elevation. then i went about 25 mph.
one thing i wish i had were electric fans, which would definetely help out.
![thumbsup](https://www.f150online.com/forums/images/smilies/thumbsup.gif)
![rocker](https://www.f150online.com/forums/images/smilies/rocker.gif)
mods for the tow:
-detroit truetrac
-transgo shift kit
-gibson exhaust
-Diablo predator
Originally Posted by Goofyfoot
I also need something to monitor temps...Any other suggestions?
Originally Posted by crowe10
Check out http://www.dashhawk.com/ as well as scanguage. Dashhawk has more features/functionality but scanguage is cheaper.
Originally Posted by openclasspro#11
look at the info the dashhawk offers versus the scanguage=the scangauge info is more useful![thumbsup](https://www.f150online.com/forums/images/smilies/thumbsup.gif)
Facts are that the dashhawk offers many of the same info plus alot more and is a lot more flexible in its display of that info. For towing I've found the torque converter slippage counters invaluable as a proactive indicator of which way my tranny temps will be heading. The only thing that the dashhawk doesn't have that the scangauge does are Trip fuel economy and DTE which I don't need, but I do find the instant fuel economy very useful when towing. I can adjust pedal position based off of that and improve overall fuel economy. They are working on trip fuel economy (as well as instant hp and instant tq which I can't wait to play with) and tend to release new features or updates every 3 months or so. Either way they are both good tools, just depends on what you want and need. I would still recommend to the OP to check out both. I don't care which he gets
Dashhawk
Calculated Engine Load
Engine Coolant Temp (ECT)
Short Term Fuel Trim Bank 1
Short Term Fuel Trim Bank 2
Long Term Fuel Trim Bank 1
Long Term Fuel Trim Bank 2
Fuel Pressure
Manifold Absolute Pressure (MAP)
Engine RPM
Vehicle Speed
Timing Advance (Spark)
Intake Air Temp (IAT)
Mass Air Flow (MAF)
Absolute Throttle Position
O2 Bank 1 Sensor 1
O2 Bank 1 Sensor 2
O2 Bank 1 Sensor 3
O2 Bank 1 Sensor 4
O2 Bank 2 Sensor 1
O2 Bank 2 Sensor 2
O2 Bank 2 Sensor 3
O2 Bank 2 Sensor 4
Relative Fuel Pressure
Diesel/Direct Injection Fuel Pressure
Commanded EGR Duty Cycle
EGR Error
Commanded EVAP Purge Duty Cycle
Fuel Level
Evap Vapor Pressure
Barometric Pressure
Catalyst Temp Bank 1 Sensor 1
Catalyst Temp Bank 1 Sensor 2
Catalyst Temp Bank 2 Sensor 1
Catalyst Temp Bank 2 Sensor 2
Fuel Type (MultiFuel vehicles)
Alcohol %
Fuel System Status (Closed/Open Loop)
Module Voltage
Absolute Load
Number of O2 sensors
Number of WB O2 sensors
Commanded Equivalence Ratio
Relative Throttle Position
Ambient Air Temp (AAT)
Absolute Throttle Position B
Absolute Throttle Position C
Absolute Pedal Position D
Absolute Pedal Position E
Absolute Pedal Position F
Commanded Throttle Actuator
Wide Band O2 Sensor 1 Equivalency Ratio (FACTORY)
Wide Band O2 Sensor 2 Equivalency Ratio (FACTORY)
Wide Band O2 Sensor 3 Equivalency Ratio (FACTORY)
Wide Band O2 Sensor 4 Equivalency Ratio (FACTORY)
Wide Band O2 Sensor 5 Equivalency Ratio (FACTORY)
Wide Band O2 Sensor 6 Equivalency Ratio (FACTORY)
Wide Band O2 Sensor 7 Equivalency Ratio (FACTORY)
Wide Band O2 Sensor 8 Equivalency Ratio (FACTORY)
Auxiliary O2 Short Term Fuel Trim
Auxiliary O2 Long Term Fuel Trim
Wide Band O2 Sensor 1 Heater Current (FACTORY)
Wide Band O2 Sensor 2 Heater Current (FACTORY)
Wide Band O2 Sensor 3 Heater Current (FACTORY)
Wide Band O2 Sensor 4 Heater Current (FACTORY)
Wide Band O2 Sensor 5 Heater Current (FACTORY)
Wide Band O2 Sensor 6 Heater Current (FACTORY)
Wide Band O2 Sensor 7 Heater Current (FACTORY)
Wide Band O2 Sensor 8 Heater Current (FACTORY)
Wide Band O2 Sensor 1 Voltage (FACTORY)
Wide Band O2 Sensor 2 Voltage (FACTORY)
Wide Band O2 Sensor 3 Voltage (FACTORY)
Wide Band O2 Sensor 4 Voltage (FACTORY)
Wide Band O2 Sensor 5 Voltage (FACTORY)
Wide Band O2 Sensor 6 Voltage (FACTORY)
Wide Band O2 Sensor 7 Voltage (FACTORY)
Wide Band O2 Sensor 8 Voltage (FACTORY)
BOOST/VACUUM (Calculated and corrected for altitude!)
Engine Oil Temp
Trans Fluid Temp
Cylinder Head Temp
Fuel Pressure
Torque Converter Slippage
Pedal Position
Dashhawk cont
Predefined "Factory Default" Displays showing OBDII Parameter IDs (PIDs) in an organized fashion.
User defined Displays that can show any supported PID subset in a user chosen format
2 Function Digital (Two large font numeric parameters on your screen)
3 Function Digital (Three medium font numeric parameters on your screen)
4 Function Digital (Four medium font numeric parameters on your screen)
2 Function BAR (Two large font numeric parameters with an updating "Bar" gauge on your screen)
6 Function Digital (Six small font numeric parameters on your screen)
7 Function Digital (Seven small font numeric parameters in a list)
User navigation of displays via the UP and DOWN keys
Real-Time Fuel System Status (on Vehicles that support Fuel System Reporting)
Menu timeouts when no key presses are detected (which returns the user to the previously selected display)
Variable polling schedules for PIDs to reduce CAN bus load
Data Logging capability (on-board) that can be uploaded to a PC via the USB connection
The device is updatable via the USB connection and downloads / software from MSD
LED backlight color is user customizable
User selectable/changeable Alerts
0-60 Times with Speed and RPM recorded
1/4 mile Times/ET (with 60 ft and 1/8 mile splits) with Speed, RPM and Two O2 inputs recorded
0-60, 1/4 mile, and Data Logging data can be uploaded to a PC via the USB connection
ScanGauge
Fuel Economy
Fuel Rate
Battery Voltage
Coolant Temperature
Intake Air Temperature
Engine Speed (RPM)
Vehicle speed (MPH)
Manifold Pressure (not available on some vehicles)
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
Maximum Speed
Average Speed
Maximum Coolant Temperature
Maximum RPM
Driving Time
Driving Distance
Fuel Used
Trip Fuel Economy
Distance to Empty
Time to Empty
Fuel to Empty
Reads Trouble Codes
Reads conditions that set the Trouble Code
Clears Trouble Codes
Turns off the "Check Engine" light
Tells you when vehicle is "Ready" to pass OBDII testing
Make and store up to 10 rewritable special codes
to send to the vehicle computer
Easy to Operate
Simple on-screen operation
4 menu driven soft keys
User settable update rate (Slow, Normal and Fast)
A HOME key to quickly return to the start screen
User Settable Backlight Display Color
7 Standard screen colors and a custom setting with 63 possible colors.
Backlight for night use
Both display and keys backlit
User settable Off, Low and High
Big display - 50% larger than the original ScanGauge
Automatic Power Control
Automatic delayed power-down after engine shutoff
Automatic power-up when engine is started
Manual power-up with delayed power-down via HOME key
Non-Volatile memory
(stored information is not lost when disconnected)
User settings automatically saved
Up to 10 user commands can be stored and recalled
Today, Yesterday and Tank Trip data automatically saved
Vehicle settings automatically saved
Easy Installation - no Tools Required!
Cable detachable at the ScanGauge II. Can be connected on the back or side.
Easily move from vehicle to vehicle
Compact Size - just 4.8"W x 1.5"H x 1"D
ScanGauge
Fuel Economy
Fuel Rate
Battery Voltage
Coolant Temperature
Engine Speed (RPM)
Vehicle speed (MPH)
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
Maximum Speed
Average Speed
Maximum RPM
Driving Time
Driving Distance
Fuel Used
Trip Fuel Economy
Distance to Empty
Time to Empty
Fuel to Empty
Reads Trouble Codes
Easy to Operate
Non-Volatile memory
