NEED Help Please
NEED Help Please
Okay first thig first i have a 2005 F150 FX4 SCAB My wife and i are looking at trailers for camping, so i have a few questions that the dealer of teh trailer couldnt help me on what do i need to get to pull this trailer http://www.forestriverinc.com/nd/def...hoice=brochure
do i need any specific equipment or electronics? and what the most i can pull with my truck
and also what weight am i looking ta there a couple different ones listed in the brochure
Thanks to all who reply and help me out
Looks like the greatest GVWR in the brochure is 6400. I would say you are within the towing range of your F-150 with any of those units.
Based on my experience alone, I would say the most trailer weight (GVWR) these newer F-150's with the 5.4L should tow is about 7,000, maybe 7,500.
You need a brake controller... Prodigy makes the most popular one and they work great with these trucks.
Go for it and have fun.
Originally Posted by kingfish51
Looking at the brochure, the campers are within your GCWR and tow capacity as long as you have the tow package (or AM equivalent), brake controller, and weight distribution hitch.
i am not sure about gear or anything like that
I Believe it has the tow package how can i be sure it does have a hitch on it and the prewired pin connectors
You will also have 2 connectors for the trailer, a 4 pin and a 7 pin.
If the trannie cooler up front looks like this one and not smaller, you have the tow package.
Which model(s) are you interested in? I've been eying the 232, myself. Take a look at RV Wholesalers for some great pricing. I read good things about that dealer W RV.net.
All Roo models should be fine for most F-150's. Since you have an FX4, you have the 5.4L and either 3.55 or 3.73 gears. You'll be fine with approriate weight distributing hitch and brake controller.
i have all that thansk so all that i am going to need is some tow mirrors and a electric brake control RIGHT?
And a weight distribution hitch. Even with the tow package, the hitch is rated for 500/5000lbs tongue and tow weight without a weight distribution hitch. With a WD hitch it would be closer to 800/8000 (can't remember the max for your vehicle).
