How Big??
Old 01-30-2008 | 08:31 AM
johnnyf150's Avatar
How Big??
Of a Camper trailer can you Tow with a 1992 f150,302,4wheel.I'm looking to get a campper but i'm not sure how much weight i can pull.
Thank you John
Old 01-30-2008 | 09:45 AM
APT's Avatar
APT
Towing anything with a 15 year old truck requires a thorough inspection. That said, I'd keep it to under 4000 pounds unlaoded weight rating which should be hopfully under 5000 pounds loaded to leave home.
Old 01-30-2008 | 09:50 AM
johnnyf150's Avatar
Thank you. I will be putting in a new motor and i will fix anything else it will need.
John
Old 01-30-2008 | 03:53 PM
BLUE20004X4's Avatar
As long as the truck is in sound shape, the thing should easily pull 5k. We had a 92 s-cab flareside 2wd and towed a 21 ft Baja boat, which I'd guess with trailer might be around 5500 lbs? It had a 454 and 66 gallons of fuel too, thing towed it easily. Upgrading cooling and tranny cooler is a good idea.
Old 01-30-2008 | 03:59 PM
johnnyf150's Avatar
Originally Posted by BLUE20004X4
As long as the truck is in sound shape, the thing Upgrading cooling and tranny cooler is a good idea.
Thank you for the tip. I will say it pulls a ton of pellets like nothing.
John
Old 01-30-2008 | 05:28 PM
APT's Avatar
APT
There is a lot more wind resistance with an RV vs. a boat.
Suspension, springs, busching, ball joints, would begood areas to investigate. I'm to worried about pulling power. I'm sure that truck can move 20k pounds.
Old 01-30-2008 | 05:38 PM
johnnyf150's Avatar
The truck is nice to start with,Solid.I'm going to lokk into the front since its one area i like tight.
John
Old 01-31-2008 | 09:22 AM
APT's Avatar
APT
I meant not worried about pulling power.
Anyway, most 1/2 ton trucks are happy pulling 5-6k pounds. Any more, any most people's comfort/safety level is lowered.
Make sure to use a WD hitch and proportional brake controller like the Prodigy.
Old 01-31-2008 | 09:41 AM
kingfish51's Avatar
What rear is on the truck? If a 3.08, I would not tow more than about 3-4k totals as it will overwork the transmission.
Old 01-31-2008 | 10:08 AM
johnnyf150's Avatar
How could i find this out?? You can go down the Highway at 75 no problem.
Old 01-31-2008 | 10:15 AM
kingfish51's Avatar
Check the tag on the door, it will have a code for your axle, and the list of codes have been posted many time, or check the tag on the diff itself.
Old 01-31-2008 | 10:21 AM
johnnyf150's Avatar
Thanks kingfish. i'll get back tp you.
Old 01-31-2008 | 01:18 PM
I wouldn't worry too much if you have 3.08's, just lock it out of overdrive when you tow.
Old 02-01-2008 | 08:01 AM
johnnyf150's Avatar
Thanks Glc
Old 02-01-2008 | 08:23 AM
kingfish51's Avatar
Tow capacity on a vehicle with 3.08 is at least 1500lbs lower than one with a 3.55.
