do i need a brake controller?
How heavy will the trailer be when loaded?
If it is under 3,500 pounds loaded, you can get by w/o trailer brakes... if it exceeds 3,500 pounds, brakes are a necessary commodity.
Also, if the trailer is equiped with brakes, you will need a brake controller such as the Prodigy in order for your truck to 'tell' the brakes on the trailer what to do.
Brake Controller
Check your state laws too. There are regulations about weight and when a trailer needs brakes. Odds are, if your trailer has brakes, you need to use them. The prodigy is easy to install if you have the towing package. It took me about 30 minutes start to finish. A big portion of that was just deciding where to place it. Got mine off of internet for $115 shipped including a Ford wiring plug.
Originally Posted by acadianabob
Check your state laws too...
DOT standards for required trailer brakes adopted by most states:
Commercial:
Any trailer with a GVWR or 3500#'s and over
Any trailer under 3500#'s GVWR that will influence the control of the tow vehicle under emergency conditions.
Personal Use:
Any trailer no matter what GVWR that will influence the control of the tow vehicle under emergency conditions.
Any trailer GVWR in excess of 3500#'s
Look at your VIN tag...if the GVWR is greater than 3500#'s you should have a brake controller to control the brakes. Since you stated that the camper trailer has dual axles you have a minimum GVWR of 7000#'s, or up to 14,000#'s which is double the weight that requires trailer brakes that operate.
The short answer is YES. It is best to have one for safety even if you think you don't really need one. The Tekonsha Prodigy is the most popular one around. I use one when towing my travel trailer and you can't tell it is back there when braking. You just set it and forget it when you install it. It works great.
In some states, mine anyway, I think any trailer with more than one axle must(by law) have brakes on at least one axle regardless of weight. I use a Tekonsha Primus its very similar to the Prodigy. The Primus & Prodigy are among the best controllers on the market.They run about 100-120$. They have sensors built in that read the trucks speed and apply the trailer brakes proportionally. Meaning the faster you stop the truck the harder the trailer brakes. There are much cheaper controllers out there, 40-60$. They work more like brake on, brake off, the same pressure all the time. They do not have the speed sensor or the ability to apply a "calculated" pressure. Any brake controller is far better than no controller. No controller=no trailer brakes.
This site shows some diagrams that may be helpful.
http://www.marksrv.com/wiring.htm
