Tongue Length
It's a greater percentage.
The exact amount is determined by load placement as well as axle placement.
If a trailer has 500# tongue weight and a 4' tongue on a 16' deck trailer and you extend the tongue 1 foot without changing placement of the load, you'll gain approximately 25# additional plus the weight of the tongue extension. Assuming you have a 60:40 axle placement.(as it should be)
With a 50:50 axle placement you will only gain about 5# plus the tongue extension.
Even with a 60:40 axle placement if you change the placement of the load you could essentially negate the tongue gain including the added weight of the tongue extension.
EDIT: Sorry that is as clean as I can explain it.
