3.55 to 4.10
3.55 to 4.10
Hello all- I am doing a gear change from 3.55 to 4.10. I will be towing a 2003 Salem 30ft. TT loaded approx. 7,400#. I wanted the gear change to get me into a better torque range.
the truck 99 f150 4x4 5.4L tow package with K&N fipk, superchips micro tuner, and a cat back 1 in 2 out exhaust.
Should I expect much of a change I just want to be able to go down the road at around 60, or with a head wind and not feel like I am beating up the truck.
thanks.
ps reason for the 4.10 and not 4.56 or4.88 is this will still be a daily driver.
thanks.
The 4.56 or 4.88 would definately handle head wind and hills better being a more radical gear change but you could also expect major reduction in fuel economy.
I know you probably know this but since you have a 4x4 you need to change both axles gears so you will not tear up the t-case in 4-wheel drive.
[QUOTE=The 4.56 or 4.88 would definately handle head wind and hills better being a more radical gear change but you could also expect major reduction in fuel economy.[/QUOTE]
i recently did a gear swap from 3.55 to 4.56 with 32" tires. best thing i ever did. my mpg have increased while towing and for everyday driving, so i don't think you should expect a "major reduction in fuel economy" unless you drive alot at interstate speeds while empty.
