yes or no
yes or no
i know this has been beaten in the ground, but i need an answer.....we hvae the chance to buy an 09 cherrokee 31b. it is 7400# dry and that is with propane, battery, and awning. it is 37.5ft long. truck is an 08 f150 5.4 3.73ls 4x4 5.5ft bed. i have the p3 brake controler and equalizer hitch.
would you pull it?
would you pull it?
Until some idiot pulls out in front of you and stops! You have to try to perform an emergency maneuver with 40' of heavy camper behind you that is way over CGVWR. We'll see you on the evening news. SD territory with a long wheelbase.... think crew cab long bed.
No.
Dude!
Not even close. The 7400 pound dry thing gave it away. Your rig would comfortably tow a trailer with 7400 as a TOTAL loaded weight... and it would struggle up steep grades. But you would be in good shape.
That trailer is likely to approach 9000 when loaded up... don't do it.
Dude!
