2008 F150 Limited AWD - swap to 20" tire to increase towing?
Looking at the owners manual, a 2008 F-150 Crew Cab 4x4 (139" wheelbase) with 20" wheels (275/55/20), and 3.73 gears, has a towing capacity of 8800 lb. The AWD Limited I own has a towing capacity of 5100 lb. The tires (275/55/20 and 275/45/22) are almost exactly the same diameter so I am assuming that it is the lower profile 22" tire that is causing the lower tow rating. Could I put a set of the 275/55/20 on my Limited and expect the same towing capacity of the Regualr 4x4? apprx 8800 lb?
Also, is there anything else about the Limited that casues this decreased towing capacity? Maybe the softer, sports suspension? Any help would be greatly appreciated.
Why would sports suspension be softer?
Anyway, I think we've been here before. Are you sure you have AWD? I thought the only AWD F-150 was the HD. If it is the standard 4wd system, going to a more load-rated tire will get you back to 8k+ tow ratings. If it really is AWD, then you are stuck with the lower rating. I still wouldn't want to tow more than about 7500 pounds with any 1/2 ton.
yea, it is the AWD system...the same as the HD...the tires on there now are the 275/45/22 with an XL load rating...I was hoping it was the lower profile tire...oh well...doubt that I will ever tow that much, but it does kind of limit the size of boat I was looking into purchasing! Thanks for the replies.
It's those heavy chrome letters on the bed.
I wanted a Limited soooo bad - and found a dozen of them locally. I need to tow, so I looked into it like you. I never found out why the load capacity was so low, but I also got digusted before I could find out. I still think it's the tires and rims. Even though the tires are P-metrics with Extra Load Capacity, has anyone actually looked at their load? It may be extra load, but an average 22" may only have a 1,500# rating where an extra load 22" has 1,800#. I'm betting it is the 22" rim over anything. I haven't heard of a heavy load 22" rim with such a small bolt pattern.
![lol](https://www.f150online.com/forums/images/smilies/lol.gif)
Actually, going with a smaller sidewall will drop the load capacity. The tires use the air to support the load and disperse the heat, so less air you can put into a tire (by volume, not pressure) the less your tire is able to support.
Now, would the difference he is talking about make a difference in his application, maybe, maybe not.
