Newb questions about electronic brake controller hook up
I am going to order a brake controller here this week. Not sure which one yet. My question is about the install. My truck has the tow package and I have read some about this subject. From what I understand I can just plug this controller into a port under the dash right?
Right behind your ODBII port above the gas pedal is a grey connector that a brake controller will plug into.
If you have the tow package, your truck came with a wiring harness that plugs into this connector.
You will still need to connect the wires of the wire harness to a brake controller.
The exception to this is a Tekonsha Prodigy wiring harness. If you buy the optional application specific harness seperately it will just plug into the Tekonsha Prodigy brake controller as well as just plug into the truck connection with no seperate wire connctions needed to be done by you.
The fuses and relays should already be installed from the factory in a 2005 truck.
Thanks for the help osprey! My truck was bought used and it does not have the wire harness in the glove box.
This is the harness I need though correct?
http://www.rvwholesalers.com/catalog...productid=1950
And is this the correct controller?
http://www.rvwholesalers.com/catalog...p?productid=60
So if I buy these two items it should be very easy to hook this thing up? Just plug and play?
I notice this controller does not have the sliding lever like most do. I am assumign this thing is totally automatic. That sure makes things easy. Especially for a Newbie to towing trailers.
As far as the connections go, that is the exact harness you need, just plug and play.
