What is the best frame mounted hitch?
I have a 1998 f150 4x4, 5.4L, Reg. Cab, Factory tow package, 3.55LS. The factory frame hitch has seen better days (Rusty and abused), and I have often exceed the weight limit. (5000# with out WD hitch.)
I want a biggest and best custom frame mounted hitch available. Something that exceeds the 7700 tow limit of my truck. What brand or part # do you recommend?
I was looking at a few Curt hitches from Summit Racing, one was class 4 (10000# max without WD) one is class 5 (Around 12000# max without WD)
The only available 2" recievers with class V rating is by Curt/Putnam. To keep that classification you will also need one off their ball mounts. (EDIT: all other class V hitches require a 2.5" ball mount) The class V 2.5" ball mounts are not available everywhere and are pricey compared to a class III/IV 2" ball mount.
Personally class III with a class IV endorcement is more than plenty for any half ton truck. Any major brand from U-haul, Draw-Tite, etc., etc., etc. and they all have the same overall design and insurance liability keeps them made well. I like 1 piece mounts instead of 3, but that is just me.
Thanks for all the suggestions.
This is the one I was looking at. It sure looks like it is class 5.
http://store.summitracing.com/partde...15+4294860906+
I will be adding a WD set up if I purchase this model.
As for my ancient leaf springs (They may be 10 years old but only have 85K miles on them)..........They have been updated with 2 new add-a-leafs on each side plus hell-wig helper / overload springs on top of the updated spring pack. I think I'll be fine.
Is the hitch and spring overkill along with my load E tires? You bet, but it doesn't seem so silly when I'm pulling 6-7,000 pounds through the rolling hills of Ohio.
But sooner or latter I'll have to step up to a 3/4 ton (Probaly when my tranny gives out). Until then I'll have to use my ancient, undersized 1/2 ton truck to get the job done. I'm just going to enjoy not making any monthly payments until then.
