Buddy buys Tundra to pull 7500lbs.
#31
Suposedly they have come up with a "fix" but they still warn their customers that the tailgate is rated to hold any amount of weight, and the best thing to do, when loading heavy stuff in the bed, would be to take the tailgate off and load directly in the bed, then remount the tailgate. Haven't heard any improvements after that.
#32
![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
Llike I said, everyone's a fan of a specific make. Some like one truck, some like another. I drove a Tundra. It's nice, but not for me (if I wanted a truck that big, I'd get a 3/4 ton). My next truck will probably be a Dodge. Why? Lifetime warranty. Who cares what it's made out of if you can just take it back to the dealer when it breaks?
Regarding that video test, it's an unscientific bunch of garbage anyway. They've got a frame sitting on hard mounts (read: no suspension, no body, no nothing) and they're hanging weight off of one corner. What does this have to do with reality? Now, I don't know about you, but I'm generally not putting a bunch of weight like that focused in one corner of the truck bed anyway. Keep in mind that torsional strength, from an engineering standpoint, mainly comes into play for giving a smooth ride, and I thought the Tundra rode better when I test drove it. Plus, a structure meant to flex will last a lot longer than one that's unyielding.
Regarding the tailgate breaking, don't stick 800lbs on it -- are you guys driving cars into your truck beds? In addition, if you're really trying to throw half a ton in there, wouldn't it be prudent to take the unsupported sheetmetal tailgate off on any truck anyway? I don't care what truck it is, I'm not sticking 800+lbs cantilevered a couple of feet out on something made out of just sheetmetal and supported by two relatively thin steel chords...
In regards to the strength of the frame itself, if you guys were so hard on that, why aren't you driving Titans? They've got the strongest 1/2 ton frame...
The C-channel vs. hydroformed box argument is moot. If you don't trust the Tundra because it's C-channel, then you shouldn't trust any Superduty out there except the newest one. You also shouldn't trust almost every 18 wheeler out there.
So, once again, your friend got a Tundra and wants to tow 7500lbs with it. As long as he's under his weights on all axles and his GVWR and GCWR, who really cares? Do you stay up, unable to sleep, thinking about how much his bed is flexing? Must be nice to have so little to worry about...
#33
Have you heard of matal fatigue? How bending a metal makes it more prone to failure? Kinda goes a different direction than your thoughts on this
So, once again, your friend got a Tundra and wants to tow 7500lbs with it. As long as he's under his weights on all axles and his GVWR and GCWR, who really cares? Do you stay up, unable to sleep, thinking about how much his bed is flexing? Must be nice to have so little to worry about... ![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
#34
![Cool](https://www.f150online.com/forums/images/smilies/cool.gif)
#35
What do you mean what does that have to do with reality? Trucks are not unibody, the bed and cab do not even touch and the frame is the ONLY thing keeping all these parts together. I have put alot of weight on my truck like that when I traverse a ditch and the suspension is pushed to the max on opposite ends. The frame on my 2004 Dodge Dakota was so pathetic when I did this it allowed the cab to touch my bed leaving as dent in my cab.
So I guess the Tundra owners are going to air lift an ATV into the bed so they dont stress thew tailgate? My ATV weighs in at almost 700 lbs and the only way to get it into the bed is over the tailgate. Taking the tailgate off is a pain in the ***, Dodge, Chevy and Ford owners dont need to do this so why should a Tundra owner have to? Also those with reverse cameras have wiring connecting the tailgate, what are they going to do? Fact is the only way to get items into a bed is by going over the tailgate, Toyota screwed up and made it too weak. Stop making it sound like the operators are the problem, it is the **** poor design
Same things these knuckleheads are basing the "the Tundra is a POS" rants on: Manufacturer proganda. Haven't seen the Titan commercial with the chains breaking when the train pulls the fram against some pillars?
The superduty, and most 3/4 & 1 tons) use a C channel frame because these trucks are used for a wide range of purposes and have many bed configurations OEM and aftermarket that need to be bolted up. Bolting up items to a fully boxed frame would require much much more work so Ford uses a stronger C channel to make installation of these items bolted to the frame. Ford engineers have said this numerous times.
A truck that is overloaded is a saftey issue. GVWR on 1/2 tons has gone out of control and these trucks cant pull loads this size in a safe manner. If you were more knowledgable about trucks & towing you would already know GVWR & GCWR are just numbers to help sell products.
For the record: I wouldn't ever tow more than 7500lbs with a 1/2 ton, regardless of ratings.
Out of curiosity, do you have any education or experience in materials or structures?
#36
You know, I meant to post something in regards to that, but there was so much in the way of unfounded opinions (likely straight out of someone's ***) that I forgot. Nothing says "I don't give a ****" like glaring grammatical errors. ![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
Don't crash then... ![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
Of course, this probably has to do with the monumental weight gains 1/2 ton trucks have been experiencing. Seriously, if you need to haul that much crap around, but a 3/4 ton...
And whatever happened to "compact trucks" that were actually compact?
#37
You tell me which one you'd rather drive
![smoke](https://www.f150online.com/forums/images/smilies/smoke.gif)
#38
Sure have. What we don't know is the construction of that joint that's allowing the flex. If it's just riveted together, probably not an issue. If it's just welded, then you might. In addition, the type of steel used will come into play here. For example, spring steel has VERY high fatigue resistance. Now, obviously, it's not made out of spring steel, but I guarantee you something as glaring as this, if it were an actual fatigue problem, would've come up in their design studies.
Has anyone done a similar test as Ford did to these C channel Superduty frames? I think you'd be surprised how much those frames flex torsionally. Remember, no matter how strong the individual channels running the length of the truck are, their torsional ridgitiy is only as good as the crossbars that connect them. If you look underneath a Superduty or Semis, you'll see some pretty beefy C channels running the length of the truck, but the crossbars are comparatively tiny. The "new" F-150 (it is, after all, 4 years old now), in an effort to give it a more carlike ride, has a lot more in the way of crossbars. Does this increase its payload? Not by much. It does, however, help out with keeping bumps in the suspension, which is what your rear end feels in the seat.
Lol. Now you question my knoweledge on such things? Have you even read my post? I'm sure towing 7500lbs, as long as loaded correctly, will be perfectly fine with the Tundra as long as he drives properly. I never said he should tow 10k lbs with it. You're over reacting.
Yes, I have helped to reinforce 4 frames on offroad rigs. The stresses they see ofroad (flexing) would cause weaker frames to tear along the spring perches and where the steering box mounts. Not knowledge found in books, but life experience on what works under severe stress. Overbuilt has never failed me, underbuilt and allowed to flex has left me stranded more than once
#39
Flexible frames that bend but don't break have their place.
Hauling heavy loads just happens to be one of those places.
Don't believe me? Just watch a heavily loaded 18 wheeler take off from a dead stop. You could measure the frame flex in inches. Yet that flexi frame will go millions of miles. Put a rigid frame on it, and it could snap in a few feet. Flexible and weak are two different things.
There is more than one way to get a load down the road. Toyota goes with a more flexible frame. Get over it.
As for offroading, I've seen an old underbuilt *****'s truck crawling up the Sluice Box on the Rubicon Trail. Not sure about how strong the frame was, but the axles were moving all side to side A LOT (just retained by the leaf springs). Seems like flexible can work offroad, too. I'll bet that sloppy old ****** would not corner well on dry asphalt (too flexible?), but I doubt many F150s will go up the Sluice Box. Overbuilt and rigid is not going to help everywhere.
#40
Besides, since there are no passengers back there, who really cares? Watch the 28mph offroad video. Note that the cab doesn't move at all? That's what's important.
#42
Don't make it sound like the frame randomly snaps during regular driving, just to help your arguement.
#43
Ford rates my truck at 3,500 lbs... or there about... Rigggggght... Same with my old one... I pulled a 6,000 lb 26 ft boat with no problem and that was with stock 3.55's. My new truck, I regeared to 4.10's and I've hauled 4,200 lbs, and it was like nothing there. Gearing matters.
