Tire Pressure on Camper
Old 08-28-2008 | 10:35 PM
BigDawg99's Avatar
How many pounds of air should i put in a tire that says 65psi...it is for my camper and i put in 60 pounds of pressure...not sure if its too much or not..
Old 08-29-2008 | 07:30 AM
kingfish51's Avatar
Unlike car/truck tires, it is best to keep trailer tires at the max.
See this thread and the links in it.
https://www.f150online.com/forums/to...tion-help.html
Old 08-30-2008 | 11:55 AM
pacificnw's Avatar
My travel trailer has tires that call for 50 lbs. max.
And that's what I have run in them since day 1. Works great so far.
Old 08-30-2008 | 07:36 PM
acadianabob's Avatar
Load Rating C is 50 pounds. Load Rating D is 65 pounds. Max out your trailer tire pressure to avoid sidewall flex which can cause sway or eventual overheating of the tire due to flex; and then you get a blowout.
Quick Reply: Tire Pressure on Camper
