Two quads in one truck
I'm trying to figure out how to put two quads in the back of my supercrew 5.5' bed. I'd like to avoid standing one up if possible. With the tailgate down I have just under 8' of space. I though of turning each sideways, or one sideways and using a couple boards under the last one. Rough dimensions on the quads are 4'x6'. Any ideas?
This is the rack that would possibly work. Ultimate ATV Rack. It does not say if it will work with the 5.5' bed, but I am assuming with the tailgate down it would not be a problem. At $1400, an aluminum 2 place snowmobile trailer would be cheaper and work better. You would still have full use of the bed, not to mention the ease of hooking up to the trailer vs. loading this contraption.
I built a rack like the one that trackerbrent linked to. I have about $150 into it, lucky I got all the metal for the frame of the rack from the crates that Yamaha use to ship their wheelers in (lucky I am good friends with the dealer). I have pics of it loaded in the bed of my 04, but the pics on on my other computer which is having issues at the moment.
Too bad you aren't close to Wisconsin, I would just sell you my rack it is just sitting around taking up room. I have only used it once because I have since sold my travel trailer and now just use one of our trailers when hauling more than one wheeler.
Great concerns and questions brought up by everyone. The reasoning behind this that I'm going 1200 miles (Florida to Michigan) to deliver a quad to a buddy, but at the same time bringing mine along to do some riding. The harbour freight trailer has never impressed me and I wouldn't trust it to 70+ mph for the distance and I don't really have any use for a trailer at this point. For a bit more than the folding trailer I can pick up a used enclosed trailer. I drew a quick model to see how things would fit. I think a small frame under the rear quad would be pretty simple to make and easily dismantled for the return trip. These are both sport quads and around 400lbs each. Thoughts?
![](http://img.photobucket.com/albums/v396/zk91/Assembly1.jpg)
![](http://img.photobucket.com/albums/v396/zk91/Assembly10.jpg)
on
Looks like the blue ATV left rear tire is half on the tailgate, half off. Crazy.
If you are determined to do this, buy a sheet of 4x8 plywood 3/4inch thick.($30)
Lay it in the bed first.
The three down tires will hold the sheet in place (plus however else you strap it down).
This will give you a true eight foot floor to work with.
Then you won't one big bump away from losing your load.
17+ hours of driving is a long way to go with a precarious load balanced on your tailgate. Plus you are going to need one or two buddies to help you load and unload the two quads into the truck with your method.
Slow down to 65 mph and it will take you about another 80 minutes to get there with a cheap trailer. But it will take you alot less time to load & unload the quads, so I would not worry to much about the fact that you are not driving at 70 mph.
http://www.diamondbackcovers.com/atv...FQEoGgodBBIqnw
This is probably the best way. You can buy a trailer on craigs list for like 200 bucks though. Especially seeing as how this is a 1 time deal, go to u-haul and get a trailer for like 100 dollars and split it with your friend. my .02
I've seen the diamond back covers on a standard bed, and they look good, but all that weight is up very high, and they do seem expensive.
I agree on the U-haul rental. A 4' x 8' enclosed trailer might run $100 - $150 for a week, one way-haul. U-hauls prices can vary by where you are taking the trailer. For example, if you are bringing it one-way to an area where lots of people are leaving (like Detroit) it might be a much lower rate than if you are towing it from Detroit and leaving it in Florida.
