OEM Tow pkg tranny cooler 06 F 150
My truck didn't come with the tow package so I have the tiny tranny cooler. I'm considering aftermarket, but see that the OEM one that came with the tow pkg is reasonably priced from Tasca and should be a direct bolt on. Surface area is 126.5 cu inches, which is about the same as the larger aftermarket units. Does the OEM cooler do the job? Thanks!
The one I have now is 2.5" X 23" for a surface area of 57.5. The heavy duty OEM cooler is 5.5" X 23" for a surface area of 126.5. More than double the size.
My F150 must have been a factory freak because it is not equiped with the factory towing package, yet it has the larger 5.5" X 23" cooler. I did not have a hitch, or 7-pin wiring on the truck when I bought it, nor did it have the relays in the panel... so I KNOW it wasn't a factory tow package truck that had its hitch removed. I basically built my own towing package: class IV hitch, 7+4 pin wiring, relays and Tekonsha P3 brake controller. I am lifted on 35s and 3.55 gears, and can't remeber seeing trans temps over 165* (even towing) if that helps you in you decide.
I ride out there a few times a year, mostly for the District 37 races in Red Mountain. Most of my riding is in the Barstow or Lucerne Valley areas since it's a little closer to Orange County. Also ride Big Bear in the summer when the desert is getting to hot. Lots of fun stuff around here to ride.
