Travel Trailer Experience w/ 2009-2010 F-150 Screws?
seats in the superduty in the back are 10x better. there is only 1" of difference between the F-150 and superduty yet you don't sit on the floor of the superduty like you do the F-150. You also get a much wider seat and a wider cab area around your head. CU feet to CU feet I'm sure the superduty is bigger and as smokewagon said, once you own a superduty there is no other cab out there.
Since 2010 models have really only been on dealer lots for a month and Ford and not advertised this extra 475/500 pounds of GVWR, I suspect you'll get few or no responses for 2010 Max tow owners. However, plenty of people are happily towing (probably overloaded) 09 F-150's with the 6-spd as well as Expeditions back a couple years with the same combo. Most are pleased with acceleration, but there have been a few reports of trans hunting using tow/haul mode and you can only lock it in 3rd or 4th gear IIRC, skipping out of the top 3 or 2 gears. I got a picture of a 5.5' bed Platinum Screw 4x4 with actual door sticker payload of 1592 pounds, which is plenty
The 6-spd gear spacing is great. If you thought your old F-150 was good enough, the 6-spd will feel much better, although obviously not as good as your PSD.
Are you kampfirekid W rv.net?
I have had my 2010 Screw 4x4 with max trailer tow since August 2nd and I have pulled my 7k camper several times since then. I can tell you that the truck feels much more stable and happy pulling the camper than my 04 did. The six speed with the towhaul button on does seem to stay in the lower gears for a little bit longer than I would think necessary, but if you get out of the fuel and then back into it, the tranny seems to get the hint that you want to upshift and it does. I dont use this truck as my daily driver, because I work inside a plant and dont want it nasty, but I would not have any problem at all driving my truck everyday, even with the trailer hooked up. You will be really impressed with the ride quality difference between the 04-08 and the 09-10's. I am going camping this weekend and I will snap a couple of pics to show you what I have... Hope this helps.....
hi all What is an "AAL"? I'm very interested in your experience ab46501. I have an '05 King Ranch and a family of four and am currently pulling a TT with a UVW of 4270 lbs and my GCW is 13,000. I'm thinking of going to a larger trailer along the lines of what you have but up until I found this thread I was thinking I was over reaching the limits of my truck. Any advice for the new kid on the block?
So based on what I read here, I'm having a difficult time deciding here! Today I sold my 2000 F-250 V-10. I used it to tow the 6000 lb 23 ft Hybrid trailer. I really liked that truck, but felt it was time to change it. It only had 35k miles since I just used it for towing. It was beginning to look like a ten year old truck though.
But now I'm looking at a new F-150. Platinum or Lariat. Max tow 6 1/2 bed 4X4. The stated tow figures from Ford seem to keep me in the range I need, but now I keep thinking once you go superduty you can't go back!
My big concern is the load range of the tires. The Platinum comes with those 20 inch wheels. Not a whole lot of sidewall to cope with. Even the 18's dont have a whole lot of sidewall. Some of the places we camped at required some off-road travel with the trailer on some not too good roads. I went to the local tire store with the factory tire specs, and they are apparently adequate for the stated towing capacity, but just barely. There is no margin on them. My F-250 had 16 inch wheels and almost 8 inches of sidewall on the tires.
Too bad I can't form a coherent question here. My mind is on overload trying to figure this stuff out!
The amount of sidewall has little to do with the load rating. The 20" tires have a higher load rating than the half the rear axle as well as the truck's GVWR. Towing 6000 pounds with even 900 pounds on the tongue should keep just about any 2010 max tow package equipped F-150 under all it's ratings. With any truck you buy, you could always change the tires is you do not like them. I arranged to replace my brand new truck's tires (~250 miles) in 2003 when I got mine. Tire dealer gave me a $300 credit towards new ones. Just make sure to do this as soon as possible as the used tire value drops quickly with even 1000 miles.
Raptor is not a towing machine. Generally, the smallest wheels that clear the brakes will yield the best performance.
The OEM fan runs off the accessory belt, which takes away power from the engine all the time. Electric fans are more efficient so, when running use less power which comes from the alternator which is also uses the accessory belt for power. Electric fans help with engine power even more because they don't always run, only when needed. Ford's decision to use what they use is because it is more reliable.
Slow down a little. There are several guys on here who have done this on a daily basis year after year and they know what they are talking about.
