Trailer brake controller ???
Hi All,
New to this forum !
I just got a new F-150 Lariat (2010) with bucket seats/center console supercab.
It has the "tow package" with the 3.55 rear axle.
However I did not get the OEM brake controller, as I have an "Odissey" brake controller that works well and I have the Ford harness.
I already put the relay and fuse in the fuse box.
Two questions:
- Where do you guys mount the brake controller ?
On my previous vehicle, it fitted nicely under the dash, but on this one it would hit my leg. I was thinking on the side of the center console ?
- Where the heck is the connector ??? Looked all around under the dash, couldn't find the thing !!!
Thanks.
J.F.
New to this forum !
Two questions:
Thanks.
J.F.
I'll remove the bottom trim, under the steering wheel and see if I can find it.
the Ben or pocket you are looking at is held in with two 8 mm screws.
the non counsole trucks you can remove the trim easy and get to the screws as for the console style i dont know.
i know this is a old post but i had to correct colorado osprey before some one jacked up there dash listing to him (prying it out)
