High oil temp
That's getting up there. Wouldn't want it there for long, that's for sure. How long was it at that temp? A minute or so is not detrimental, but don't keep it up. You didn't hurt anything so don't sweat it. My personal no **** pull over and stop temp is 260. You didn't hurt the motor, it'll just start cutting into the usefull life of the oil. How are you monitoring oil temp? Not too many guys I know of besides me have a real oil temp gauge.
The Motorcraft oil is tested for hours at 302F and is not allowed to "break down" in that deposits are limited as well as any movement of the viscosity. If you have the newest GF-5 oil in the engine, the testing is even more tough especially any gassing of the oil or add pack. Your engine is fine and so is the oil. No synthetic on the market is going to help. Using a "thicker" oil only adds to the heat as a thinner fluid gathers and releases heat faster. In the old days we used a 15w-40 for high heat and heavy towing because of fuel dilution from the carbs. Obviously, you don't have a carb so the thinning of the oil from the fuel is not an issue.
FWIW, Amsoil is no longer a PAO only based oil. They've been reformulating over the last two years and finally settled on a blend of PAO and Visom from M/E, which is a GP III+. Still as strong as it always was but the cost of PAO base oils has gotten to the point where no oil maker can afford to sell it and still have customers. If you want or need extended oil changes, Amsoil is as good as it always was. It's just not worth the price for the average driver.
Correct me if I'm wrong, but the XL oils is the current line that was reformulated and it is the XL line that is a newer group III+. The SSO, ASM, and the like should still be pretty much unchanged and a PAO. This has got me to thinking though and I'm really considering going with that new XL in my new truck (if I get one!)
I would make two arguments but no one around here will ever consider them...all you brainwashed MC guys
--The new OE oil is going to be as good as any 'synthetic' on the market and is also competitively priced.
--The new XL is every bit as good, if not superior to, the famed MC 5W20 blend without all the extended drain interval hype you guys don't like to talk about. ESPECIALLY with 7,500 becoming the norm for Ford!
