questions about towing mirrors
Found it.
Not sure on the stock measurments. But I think they stick out 13"? I would measure yourself to be sure.
thanks that helps out i wasnt to worried how much farther they stuck out than stock but it was definately good to know. Did you know where by chance its the cheapest because I dont want to spend like 350 bucks for the defrosting/turn signal ones when i dont need those.
Josh quoted me with this
Power, Heat, Signal & Puddle Lamp-Black
(RH) 7L3Z-17682-AE - $134.75
(LH) 7L3Z-17683-AE - $134.75
Shipping $40.50
Total $310.00 Shipped for the Tow Mirrors Alone
Shipping $40.50
You should say something in the **All OEM Ford Parts at 10% over Cost thread..
http://www.truckspecialties.com/mirror_extensions.htm
You can save yourself a LOT of time and money and retain the better looking standard mirror by using mirror extensions. I've used these for years and I find them to be excellent for towing my travel trailer.
I heard the slide on mirrors vibrate badly though and I can't deal with that. What's your experience??
For $70, that's a bargain.
I thought about getting the factory mirrors but I have reservations mainly because they'll cost between $400 and $500 to install, not worth it to me for sure. Then they stick out pretty far when not extended. This is a pain for drive up windows and ATMs. This is my daily driver so it's has to work good for every situation, not just towing.
Thanks for the help.
I love the custom fit **** mirrors for my 2003. Amazon has the ones for your truck for $50 free shipping.
I like how they look factory when they're on and how easy they slip on. I won't have to worry about readjusting the tow mirrors after I put them on like I have to with all others since they can only install in one position and easy at that!
I've had the **** Clip on mirror which was really junk. Rubber straps break and they vibrate so much it's all a blur. Okay for a Pop Up, but not a longer travel trailer.
Also had the Tow-N-See Convex mirrors. They leave everything in the mirrors small so they work best with short Pop Ups. Actually work good with Pop Ups, better than most. HOWEVER with the Travel Trailer, I had a hard time passing since all the cars in them were so small to see. Couldn't use the standard/none convex mirror as the Tow-N-See mirror glass is just to small, leaving only a small area visible in them. Couldn't use the truck's original mirrors because they block the original mirror plus demand the original be adjusted for the tow mirrors to work. This leaves the original mirrors out of adjustment to see anything.
The **** Universals work the best but after some mileage, they tend to walk down the mirror and need readjusting. They are also more work installing them, then adjusting the tow mirrors.
So I'm excited about the **** Custom Mirrors.
I didn't want McKesh Mirrors (which are the most popular on the RV Forums) because there is the 'potential' for the straps to scratch the paint and if the mirrors are hit, they are not break aways, so they could dent the door.
What **** mirrors are you referring to?? You can put a small round or square stick on, convex mirror in the corner of any mirror so you don't have any blind spots.
