Trailer lights
Trailer lights
Bought me a 16' enclosed trailer. It has the 7 prong plug. It has interior 12volt lights. Went to go turn them on and nothing. I thought it was the trailer lights not working, so I plugged it into my father in-laws F350 and they work. So what I figured out is that my 2005 f150 factory plug is not wired up for this option. So what has to be done to have working lights?
If you look at the truck plug it is the one located in the 1 o'clock position. It should be hot when the key is on. If it is not you need to locate and install the correct fuse/relay.
Do you have a brake controller? Do you have the trailer fuses and relays installed?
https://www.f150online.com/forums/to...locations.html
