03 150 long bed sags with weight.. looking to beef it up..
thanks i ordered them... did u have to drill ? if so was it a pain? any tips?
http://www.autoanything.com/suspensi...9A3579381.aspx
No drilling required. Mine is 06 so may be slightly different install. Tips are when u get kit if u have 4 long bolts per bracket that are 9/16 u will want a ratcheting crescent wrench. Only able to get about quarter to half turn the way its in there and will save u lots of time. When re-using stock bump stop there will be a different bolt that comes in kit. Stock one is too short. I routed air lines into cab. U can see pics on my profile. They won't get dirty in there and my air compressor reaches. I didn't use jacks or anything just ramps to give me room to get under rear axle. Took me 2.5 hours and would have saved at least an hour had I not hit the 2 snags I hit.
Very true kingfish. I missed that part but figured he may be hauling grass clippings in the bed as well. If u are looking for a good priced wd hitch check Craigslist and/or amazon.com. should be able to get one around 150 or so. This will be for a lower level one, but will help none the less.400-500+ is easy to spend on the higher end ones.
