1 ton question
The most common 22's for a dually are 305-40R22 In that size your max load range is gonna be about 2600#'s per tire. That is a far cry factory weight ratings by each tire more than 1000#'s ea.
We have been putting a lot of 17.5, 19.5 and 22.5's on the newer trucks. Then you can run over the road truck tires. The main reason for this conversion is an increased load range and longevity that puts light truck tires to shame.
Even going to the 17.5's we are seeing people get 300,000 miles on steer tires.
Jumping into 19.5's and they don't even seem partially worn at 300,000 miles.
The downfall to jumping into OTR tires is the lack of low-pro coolness that you are going for.
