Upcoming Tow
Upcoming Tow
I have a 2008 Ford F150 FX4 5.4L and just purchased a 22 ft V Nose Car Hauler with the #5200 lb axels. I'll be pulling all of my house hold goods and my wifes Mazda 3. I have the EVO programmer, P3 Brake Control, and a K&N Air Filter. I'll post a picture once I get the trailer and let you know how the move went. It is about 2700 miles from Ft. Benning to Ft. Lewis.
Any recommendations on what else (parts wise or advice) I may need to make this a better haul? This is my first major haul.
Thanks,
Nolan
Thanks,
Nolan
Trailer is about 2400#'s right?
That v-nose helps a bunch.
5200# axles are actually 6k axles with 15" tires- tires are the weak link.... also trailer tires are speed limited to 60mph. Go faster and you can easily encounter a blow out even when underloaded.
You should have plenty of axle/tire combo as long as you don't tray and max out the trailer with house hold stuff.
Your maximum that you can load including the car should be around 8k in the trailer. This will be a large load for any F150. If you can keep the cargo load closer to 5k or under you will have a happier tow and less likely to have a tire failure.
Like stated above Weight Distribution bars is a requirement for those loads.
As far as OD on or off: As a general rule of thumb, if the vehicle is switching back and forth, lock it off. If you can maintain speed without it jumping in and out of OD, running in OD is ok.
Good luck and thank you for your service
A fellow Ft. Lewis member!
Lewis was my first duty station after Basic/AIT/Airborne at Benning. Lewis is great; Mt. Rainer Natl Forest, Yakima, Pikes Market in Seattle, Definace Point, Skiing at Mt Hood in June!!
Good luck with the haul and I hope you enjoy Lewis as much as I did!
Don't forget a spare tire for your trailer.
One of these are cheap and handy as can be if you have have a flat. If you have dual axles
http://tweetys.com/trailer-aid.aspx
No it doesnt, it actually can make things worse. Moreover, depending on the length of your V, it can severely limit your choices of WDH setups. If I wouldnt have gotten such a blazing deal on mine, I would have never bought it.
Edit:
This right here. Although, admittedly, I use the "poor mans" version of a double stacked 2x12 since I have them for loading the racecar into the trailer.
Also, some advice for the OP, its going to be a tight squeeze with the Mazda 3 in the trailer and packing it with other items. Make sure you strap the car down by the shipping hooks if you can, not the control arms or wheels. Especially so if you plan on having stuff packed tightly around the car. Resolve yourself to driving 55 in the right lane, your wallet and truck will thank you.
My biggest piece of advice is to plan your route and stops carefully.
Edit:
