Am I misguided or is this hole too small?
The hitch came with my 2005 FX4, so it's whatever Ford put on there. There are 2 holes that go all the way through the hitch, and I'm assuming both are for the pin. The pin goes all the way through the first set of holes (closest to back of truck) fine, it's a REESE ball mount/pin. The pin goes through the first hole (in the 2nd set of holes) but will not go through the 2nd hole when pushing the pin through left to right. I can't even begin to push the pin through if trying right to left. I'm not sure if there's something wrong with the hole itself or if I'm just not meant to use that to attach my ball mount? Here are pics:
Is it alright to have it through the first set of holes, all I'm using it for is in case I get stuck in the mud -- I literally don't tow anything. I think it looks better when it's in all the way (no pun intended). Is there a reason it doesn't go through that hole?
Well first off are you the orginal owner so its 100% guarnteed to be factory instead of a previous owner mod? Second off Ive NEVER seen a hitch with 2 holes for the pin (and part of my job is servicing probbly 100 super duties and 300 school buses). That said looking at the pics the hole where the pin does fit is where hitches and recivers are designed to be at. Personally if I was just using it for a tow strap I'd either get a pintle reciver or just wrap the strap through the hitch (possibly use the pin to hold it in place)
Well first off are you the orginal owner so its 1005 guarnteed to be factory instead of a previous owner mod? Second off Ive NEVER seen a hitch with 2 holes for the pin (and part of my job is servicing probbly 100 super duties and 300 school buses). That said looking at the pics the hole where the pin does fit is where hitches and recivers are designed to be at. Personally if I was just using it for a tow strap I'd either get a pintle reciver or just wrap the strap through the hitch (possibly use the pin to hold it in place)
There it is! Bam! Thank you, much appreciated! I'll just grind a little out then.
No, actually bought it used but I have the original sticker and all the information in my manual. It states that it has the tow package added ($350.00) with 4 pin wiring and I figured he wouldn't have changed that. Got the truck at 46k miles. I'm assuming it's the stock FX4 hitch just because it would be insane for him to pay $350 then buy a new one lol. Also everything in the book is written down for maintenance and had one accident involving the front with no frame damage...
Yeah, I can see how that would come across lmao
Yeah I didn't even think about that, the holes were perfectly aligned the same distance apart so I didn't even consider it, definitely a viable concept if not for the other's that checked their own. Good thinking.
Well first off guess you do learn something new everyday, dont know why ford would have the second set of holes but guess they do (like stated earlier this is the first Ive ever seen). My comment about the orginal owner mod was more along the lines of, the previous owner couldve gone and drilled the second hole (for whatever reasson) and didnt get it aligned right so the pin cant go through.
