In Overdrive?
It's not the in and out of overdrive that's the problem - it's the torque converter locking and unlocking. Unlocked builds up too much heat.
You DO know that the speed limit with a single axle U-haul trailer is 55 mph, right? (Tire and axle limitations) At 55, your mileage won't be too bad out of OD and the 4.6 will run better at the higher revs.
They figured a 6 hour tow and I dont think they calculated that with 55mph.
If I had a CB handle it would be Tortoise.
You'll find that no matter how fast you try to go while phycially moving, your overall AVERAGE mph for the duration of the trip is going to be in the 50-55 range anyway. This is calculating total time on the road for the day.. Stops, slow downs, lunch, etc...
I always use 50 mph for my estimating time wise and come pretty darn close!
Have a safe trip!
Mitch
Have a safe trip!
Mitch
We ended up having to get the 6 x12 Uhaul. Way more stuff to move once we got there.
I didnt even attempt overdrive with this weight, and the RPM sweet spot was around 2000.....OD in normal cruise is at 1550 @ 60.
I also have a power tune on it too, and the data chart shows an extra 13 ft lbs. at 1750- 2000 rpm , or a 6 % increase in torque (on reg. gas).
Thank ya for the support.
