trailer brake controller and 07 f150
Hey guys , wondering if you can help me. I am a noob at towing anything with brakes. I just bought an older camper trailer , 16 ft long and pretty light at about 3500 lbs gross weight. The thing is I have a factory tow pkg, and 4 and 7 pin connector at back of my truck. There is a pod bc under dash all wired up. But no light at bc manually or with brake pedal when hooked up to trailer. We put 12v to trailers brake wire and they work. But nothing happens on truck side. Weird thing is , i grounded my test light and started poking around at the bc connections and there is power. keep in mind , all lights and flashers work on trailer just no brakes. I touched the blue wire at bc with the test light (unhooked) and the bc lit up green and flashed red with brakes applied. Idk what to do
This help?
https://www.f150online.com/forums/20...r-install.html
You installed the stuff that came in the baggie in yer glovebox, right?
MGD
MGD
