Towing Speed
Towing Speed
I have a 2007 f150 5.4 with a 2.5 level kit on and 33" tires. I have a edge programer on it. My question is I just bought a 26' foot camper so actuall length is around 30' and weighs 5500 lbs. I have to pick this up about 500 miles away I will be using trailer brakes and a weight distribution hitch. I was wondering what speed I can expect towing this most will be flat interstate driving? Also do you need to take the od off I will be in towing mode on the edge. Thanks
I had the same truck with 3.55 gears with leveling kit and even the 33" tires but not sure what you have for gears?. My camper was 5600lbs loaded and i would lockout overdrive and set the cruise at 65mph and it pulled great! You should have no problems towing that trailer.Just make sure you take the time and setup the WDHitch correctly. I also believe most of the trailer tires have a max speed rating of 65mph anyway unless they are radials..
Old setup
New setup
Old setup
New setup
Since all brand new travel trailers come with the MINIMUM rated tires on them, I'd stick to no more than 65 mph for any length of time... Make sure they are at the MAX COLD PSI before you start and stay at 65 mph MAX, you should be okay...
The trailer tires are going to be the weakest link in your speed... Your truck will tow the thing as fast as you are willing to go! Not a pretty sight when a TT tire blows at speed either... Lots of damage will be done, so decide on what your own "risk/reward" is going to be concering what speed you go..
Good luck with the road trip!
Mitch
Mitch
For What It's Worth
Many Trailer Tires Have A Maximum Speed rating of 60MPH You need to see the tire specs to be sure on your particular tire.
Doing a higher speed greatly increases tire heat. Heat is the primary cause of trailer tire failure (blow out/flats) generated from high speed, heavy loads, or low air pressure.
True that ST (Standard Trailer) tires have a 65MPH maximum speed rating, but that is not the only type of trailer tire. Some have speed ratings of only 50-62mph)
There are many types/sizes of trailer tires without ST rating that you will need to check on the speed rating before you go tearing off. I am not referring to LT or P series tires either. These are legitimate trailer tire sizes.
Examples are:
4.80-8
5.70-8
16.5 x 6.5-8
18.5 x 8.5-8
20.5 x 8-10
4.80-12
5.30-12
700-15
750-16
8-14.5
Examples are:
4.80-8
5.70-8
16.5 x 6.5-8
18.5 x 8.5-8
20.5 x 8-10
4.80-12
5.30-12
700-15
750-16
8-14.5
