Equal I zer hitch
Equal I zer hitch
I have the equal I zer hitch set up, I towed my camper the other day, I set up my hitch fully loaded, and I have air bags and I loaded my wheeler up and used the air bags to set the pickup height back to stock level, then adjusted my hitch. I got it set with 4 washers, and L brackets in the middle. Now it lowered my rear by 3/4 on an inch and raised my front 1/4 of an inch. It wes well within the set up limits. Now I noticed that it seemed to bounce a lot going down the highway. What can I do to reduce that? Should I add a washer so the front is level and puts my rear back to level or does it sound like its set up just fine? I didn't add another washer because it was within their specs. Just trying to reduce bouncing. It didn't sway too bad, it was windy but I noticed the bouncing more than the sway. Any ideas?
I'm not sure what you are trying to say here but I've read that you should set up the equalizer with the normal amount of air in the airbags. I did find the following quote while searching the Equalizer web site. "Tow vehicle “auto-level” systems should also be disabled or turned off temporarily." I know that this is not the same as your manual level system but I think this means that for the equalizer to be properly adjusted, it needs to do the leveling, not the airbags. Leveling with the airbags then adjusting the equalizer will result in a setup that is under adjusted.
Well If I adjust the equal i zer when the four wheeler is in the back it's trying to level the weight in the bed as well...I don't think they can handle all that weight. Also when the wheeler isn't in the bed it will be over adjusted...? I guess i should call them and see what equal I zer says...
I would suggest calling equal-I-zer for there input just to be safe. My suggest would be to hook the trailer with the 4 wheeler in the bed. Adjust the WD hitch until you are close to level, take out roughly 2/3 of what ever drop the 4 wheeler and trailer gave you. Then use the bags to bring it completely level.
There isn't a set way to do them, at least from the air bag side of things. WD hitch manufactures may have there own take on sequence of events. I've seen people do it every way possible and of course they all say there way works great. I think it is more of a trial and error procedure for best comfort as long as both systems are at least being utilized.
Do you have a controller for the bags? Have you tried adjusting the psi +/- to remove the bounce? Might be a thought to consider, if you don't have a controller you might be able to just bring a small portable compressor for a trial run and get it all fine tuned.
In regards to the 'bounce' you are experiencing, does this seem to occur more on concrete roads as opposed to asphalt roads?
Do you still have the OEM shocks on the truck?
My opinion on when to add air to your bags is after you have loaded the bed, set the psi to where you want it. Then hitch up your trailer and WD bars. My only reference point to that is that I have some after market 'overload' springs on my truck. These are for payload and reduce sag when you load up the bed. Since I can't adjust them, I've got what I've got, so when I hitch up my trailer and set the bars, it's distributing based on it's current level.
If I did not have the overloads, my truck would sag more than it does with them when I put the tongue weight on the truck.. So, that's my story! Right, wrong, it's my analogy to the deal!
Good luck with it!
Mitch
Good luck with it!
Mitch
