going from 4 pin to 7 pin
I just bought a 98 F150, 4.6 V8, auto trans, 3.55 rear. It's an XLT Flare Side with 17" wheels, loaded and I love it. It ha a 4 Pin trailer setup and the connector for a brake control unit under the dash. I've got the control unit but how do I find the blue wire that should be under the truck somewhere near the 4 Pin connector? My trailer has electric brakes and a 7 Pin plug, although only 5 wires come out of it. Thanks.
I researched the trailer connection on my 97. I noticed that in the fuse panel there was a fuse for seperate tail lights for the truck and trailer....I liked that...when I just bought my 2002 I could not get the tow package....I took it to a hitch man and we looked into the fuse panel and sure enough the fuses were there for the trailer tow group. So I had him install the 7 pin reciever and it was a direct plug into the wireing harness below the bed of the truck...cost about $75 for the connector and about 25 bucks for the labor.....that way if you ever have to use a trailer that uses all the wires....your set!.......good luck Bob Johnson
