Towing kit for expo
Towing kit for expo
Good morning all. I am new to this board and have questions about my recently purchased 99 EB Expedition.
I own a 93 Cobra that I show and race. As I stated above my wife and I recently purchased an Expedition. It has a 5.4 and 3.31 rearend. I know that it will tow my car without any problems but it did not come with a towing package.
My questions are:
1st) Is it feasble to buy the auxillary trans cooler and lines that came factory equipped on f-150's and/or expeditions to install on mine. Where can I buy it? I have not found a place as of yet to buy this item. I have received a price for the receiver and 7 pin connector.
2nd) What type of rearend is in the Expeditions. I am pretty sure mine does not have the trak-loc and I want to buy a trak-loc carrier for my expo so that I can install it.
My questions are:
You'll have the 9.75 rear. If you are changing to a LS, I would recommend the Auburn gear unit over the trac-lok, which is pretty weak.
The factory cooler can be purchased, but you would need the lines as well. I tried to update my cooler to get the larger one that came with the 4R70 (I have 4R100) but found that the fittings don't match. It would be a lot easier (and cheaper) to get an aftermarket cooler.
Also, the towing pkg includes a heavier duty rad, so you may need to upgrade that as well.
Finally, I think the 3.31 is too tall for towing. You should look at a 3.73 or 4.10 gearset to get the revs up.
Ian
Ian
I have 3.73 gears in my Expy, it tows fine, 7000 +lbs. If you keep the 3.31, be real easy on the throttle and you will NOT be able to tow in od. The rpm will be too low and the TQ converter would be locking and unlocking too much, building heat and would eventually kill the tranny. I bought a Screw a few months ago and it pulls a lot better than my Expy.
