Bed Anchors
Tie downs
When I first got my 99 Effie, one of the first things I did was throw out those hold-down cleats in the bed. Cleats belong on a sailboat, not a pickup truck! FORD, HOW COULD YOU! Not only are they flimsy pieces of metal that could easily buckle under a load, but they are also open-ended. This could easily lead to a ratchet strap popping off and hitting you in the face or worse yet, loosing your load on a rough stretch of road. Luckily, there's an easy fix to this problem. Underneath the cleat lies a ½ inch dia. hole. Go to the hardware store and pickup 4 eye bolts with ½ inch dia. shanks, 8 nuts, 8 fender washers and 8 lockwashers. Remove the cleat. Screw a nut, lockwasher and then a fenderwasher onto the eye bolt. stick it into the hole where the cleat used to be and have a friend hold a wrench on the nut. Slide underneath the truck and reach up in between the bed wall and the inside of the fender and locate the end of your eye bolt. Pop on another fenderwasher, lockwasher then a nut and crank it down with a wrench and your done! If you break one of these babies , you got to quit haulin' bulldozers in your bed.
