Axle Identification
Old 02-15-2003 | 04:36 PM
p40whk's Avatar
Question Axle Identification
I want to change the gears in my rear axle and plan on getting a used axle and swapping it out but am not sure how to identify which axle is which.
The 3.55 rear axle uses to different sets of tags:
S862A, S862B and S862C or,
S869A, S869B and S869C.
Which one is which? And, what do these designators mean?
I know these are for the 8.8" rear end but I want the best possible unit for towing. any help would be appreciated.
Old 02-16-2003 | 07:44 PM
DoggieDoc's Avatar
Why don't you just swap the ring and pinion. It seems to me that would be much less complex.
Besides, it may even be cheaper.
Old 02-17-2003 | 09:29 AM
p40whk's Avatar
Swap ring and pinion
I thought about that but decided that it would cost more since I wanted to go with limited slip. By the time I bought the ring and pinion gears, the differential, and the bearings I was at $650 (from Reider Racing). Then I either have to install it or pay someone to do it.
I can get a low milage axle from a salvage yard with a 3.55LS for about $700 and installing that doesn't reqiure all the measurements and set up that changing the gears do.
I'm pretty mechanically inclined but I don't have the measurement equipment to install new gears and am not too sure if I can do this myself.
Old 02-17-2003 | 03:31 PM
DoggieDoc's Avatar
Now that's a different ball of wax. I aggree and axle swap would be better provided you can find one at a recking yard that is low milage and in good shape. I don't know what to tell you about the codes. I remember seeing and L in the number on my mustang which is limited slip. Trac-loc I think.
If I remember - 3.L27 or something like that. Its too cold out and the car is too low to the ground to look right now.
My truck is different, so I will look later when the ice melts if you haven't found out.
Old 02-17-2003 | 08:26 PM
p40whk's Avatar
Crawling under a truck with all this snow and ice! I did it because, well, ...I want a new rear end!
The reason I need to know is the junk yards use the codes on the tags that are on the axle (which I listed on my first post) It seems stupid that they dont use the same codes that Ford does on the vehicle information sticker.
I think I found one at a local yard but their computer was down from all the damaged wires from the ice storm.
Thanks for looking if you get to it.
Jeff
Old 02-18-2003 | 10:19 AM
DoggieDoc's Avatar
sorry Jeff -
Mine says S836J
3 08 88 5801
I have 3.08 open diff 8.8
I guess it won't help.
I'll ask around.
Quick Reply: Axle Identification
