A4OD Fluid Types
Old 02-19-2003 | 11:40 AM
cwelk's Avatar
A4OD Fluid Types
OK, I have a 97 F150 with the E4OD tranny and am about to change the fluid and filter. My question is this.. should I use MerconIII or V? Its a 97 model 5.4 with 63,000 on it. Cost of the fluid is not a factor I just want it right
Old 02-19-2003 | 12:24 PM
AjRagno's Avatar
The E4OD requires "Mercon" fluid.
Old 02-19-2003 | 12:37 PM
cwelk's Avatar
I guess what I should ask is which type of mercon, Type 3 or 4?
Old 02-19-2003 | 12:55 PM
AjRagno's Avatar
Ford just says Mercon.
Old 02-19-2003 | 11:09 PM
Mark Kovalsky's Avatar
There are two types of fluuid, MERCON and MERCON V. The E4OD requires MERCON, not MERCON V.
Just to muddy the waters, there is a new MERCON SP fluid for the new TorqShift 5 speed automatic in the diesel trucks. That is not compatible with any older transmission.
Old 02-20-2003 | 12:23 AM
BlueOvalFitter's Avatar
Just out of curiousity,why cant you use MerconV in this tranny?Dont say because Ford says not to,but why they say not to.And AJ,when will your site be up and running?
Quick Reply: A4OD Fluid Types
