Rear End Thump
Old 04-08-2005 | 10:41 PM
masterd's Avatar
Rear End Thump
I have a 2004 F-150 with the 5.4 V-8 and when I take off from a stop....under moderate throttle...I get 2 thumps from the rear it seems and then a slight shimmy...and then its moving.....Ive already had the rear replaced from the whine at around 50mph.....and I noticed that when I put significant weight in the back...then thumps go away...any help?
Old 04-08-2005 | 11:03 PM
WVtrucker's Avatar
U bolts loose maybe? That could cause the diff to move around a litttle causing a thump. Might check it if they replaced the diff.
Old 04-09-2005 | 12:01 AM
masterd's Avatar
If i recall....it did it with the old 1 too...
Old 04-12-2005 | 06:42 PM
mg175150's Avatar
There seem to be several newer threads in "Transmissions" that identify the exact symptoms you are talking about. I am personally trying to solve the exact problem you have on my 1999 F150 5.4 V8.
So far I have changed the tranny/torque converter fluid/filter and replaced the rear axle fluid. No improvement yet. I have heard it may be the slip yoke, leaf springs, or even the spider gears.
One thing I did try on my truck was to hold the brakes and then press the gas. Almost like a brake stand without spinning the tires. The rear end thump was still present even though I had not moved. This leads me to believe that it may not be the leaf springs or the spider gears.
I will continue troubleshooting and post any good news.
Old 04-12-2005 | 08:42 PM
zapster's Avatar
well with weight in the back and it goes away...it sounds like a suspension problem...something is shifting with weight..bad shock mounts? worn rear bushings?..look around the rear springs for any wear...zap!
Old 04-12-2005 | 08:52 PM
1Ford-Fan's Avatar
The clunk you are feeling sounds like it is comming from your rear driveshaft slip yoke. You can remove the driveshaft and lube the slip yoke with teflon grease. I hope this helps.
Old 04-13-2005 | 08:21 AM
acadianabob's Avatar
Yes, I'd bet on the yoke. It's a common problem.
Old 04-15-2005 | 07:27 PM
masterd's Avatar
Thanks for the help guys....apperciate it
Old 04-17-2005 | 01:17 PM
suncoast ford's Avatar
What is a "slip yoke"?
Old 04-19-2005 | 10:43 PM
The purpose of the slip yoke is essentially to change the length of the driveshaft to accomodate suspension changes due to load.
Old 04-22-2005 | 02:13 PM
Boatboy1996's Avatar
Question thump
My 97 150 4x4 has thumped since new. Why would the yoke make tha tnoise and not fail after 8 yrs?
Old 05-03-2005 | 09:54 AM
mg175150's Avatar
Well I believe the "rear end thump/jerking at takeoff" has finally been fixed. Sure enough it was the simple greasing of the slip yoke. I used Mobil 1 synthetic u-joint grease. No thump what so ever at least so far. Simple fix that takes maybe 20 minutes!
Quick Reply: Rear End Thump
