Torque Converter Fluid Change
Old 05-01-2005 | 08:32 PM
MLD's Avatar
MLD
HI,
I HAVE AN 02 F-150
HOW CAN A DOITYOURSELFER DO A COMPLETE FLUID CHANGE
ON A TORQUE CON. W/NO DRAIN PLUG??
ONCE I HAD A BEATER 87 BRONCO & WOULD PULL THE COOLER LINE & start ENGINE .
AFTER IT PUMPED OUT I SHUT THE MOTOR OFF THEN DRAINED THE PAN.
NOT EXACTLY SOUND SHOP MECHANICS ESPECIALLY IN LIEU
OFTHE FACT THAT THIS C-6 HAD A PLUG IN THE CONVERTER.
I PUT 175,000 MILES ON THE TRANS. AND NEVER ANY PROBLEMS
Old 05-01-2005 | 09:40 PM
dirtyd0g's Avatar
I don't recommend doing that yourself unless you have machine shop type experience.
Alan
Old 05-02-2005 | 07:47 AM
casey_1's Avatar
I've used this method several times to change ALL of the fluid without having a torque converter drain plug.
Trans Fluid Change
Quick Reply: Torque Converter Fluid Change
