GK_crewchief's SD Tran Cooler install + How-To with loads of
Old 10-05-2007, 10:50 PM
SWThomas's Avatar
The push pins are a pain to get out and can cut your hands. So I just cut the heads off all of them and used some new ones I already had to re-secure the splash guard. You can find them at just about any auto parts store. I got mine at Advance Auto. You can see the part # in the pic...
After the splash guard was re-secured, we decided to install the NAPA Transmission Filter (NAPA Part # 1622) on the filter mount. Jeff filled the filter with trans fluid and lubricated the gasket before installing it. I used my razor knife and cut a hole in the splash guard for the filter to protrude through...
Old 10-05-2007, 10:51 PM
SWThomas's Avatar
Then we re-installed the grille support, grille, headlights, corner lamps and radiator cover in reverse order from what was mentioned above. Here's the finished product...
I am very happy with how this install went and so is Jeff. He text messaged me a few times on his way back to NC to let me know what the trans temps were. He saw 145 degrees on his Auto Meter Trans Temp Gauge pretty much all the way back. If anyone has any questions about this, please PM either Jeff or myself.
Old 10-06-2007, 11:59 AM
Galaxy's Avatar
WOA dude..great write up!!!! You spent more time on this than you did installing the stupid thing
One thing I might add on to this since I don't know (or didn't notice) a difference between the Lightning and a regular F-150, but I never needed to remove the grille or anything from the front end. Once I removed the center hood latch bracket thingie, my cooler went right into place and I could get to everything I needed to within that space.
Old 10-06-2007, 09:38 PM
SWThomas's Avatar
Yeah, the Lightning is a little different. The way you did it wouldn't be possible with a Lightning. I posted this in here mainly so people could benefit from the actual install of everything to see how it's done.
Old 10-07-2007, 07:39 PM
koharatx's Avatar
Excellent writeup!
Those fittings are different from what I use at work, but I don't suppose anything on a vehicle (other than diesel?) has to deal with 3000 psi. What are your fittings rated psi?
Old 10-07-2007, 07:42 PM
SWThomas's Avatar
Originally Posted by koharatx
Excellent writeup!
I'm not really sure...
Old 10-07-2007, 11:22 PM
Galaxy's Avatar
I used Earl's and don't know the rating on those either but I can tell you this...it's substantially higher than anything they'll need to deal with on a car!! (or truck)
Old 10-08-2007, 12:02 AM
GILTYLER's Avatar
Very nice job and pictures I have that cooler on my E-250 work van.
I may add one to my truck in the future.
Old 10-08-2007, 10:33 AM
Ilovemyford's Avatar
Great write up Thanks
Old 10-11-2007, 11:12 AM
mattyk6's Avatar
Awesome! Thank you for taking the time to document this. I especially appreciate the part about the hose. I don't know if I'll go that route, but it will be a very useful piece of knowledge.
Quick Reply: GK_crewchief's SD Tran Cooler install + How-To with loads of
