Clutch Wont Disengage...HELPPP
Old 02-29-2008 | 10:43 PM
Originally Posted by glc
That's more like it. $850 *including* labor.
Yeah... it's very cheap to own a manual.
With my 4.10's I barely need to use the gas to accelerate from a stop... so it puts like hardly any wear on the stock clutch lining... it's kind of funny.
I can say that my crawl ratio is nice... 1st gear and I'm doing like 4 mph... I can get out of my truck while it is in gear and walk next to it.
Old 03-01-2008 | 01:11 AM
The way you drive you will get 200k out of the factory clutch.
Old 03-01-2008 | 06:00 AM
JMC's Avatar
JMC
Originally Posted by koreyw69
so the shop said it would be around 950$ for a brand new clutch, flywheel, slave cyl, master cyl, and hydraulic line. plus labor. he said he didnt think i would need a master cyl to so without that it would be 850$. if he goes in and finds out the clutch and flywheel arent in need a change then its goin to also decrease the cost by alot. do you guys think this is goin to be a good deal. he said it would be a one day job and im really wantin to get this truck up and goin.
MAKE SURE THEY INSTALL A NEW PILOT BEARING Sorry for the caps, no I am not. I do not see it in the parts that they are replacing. It is one of the most critical parts for proper clutch and transmission life. Ask to see the old one when the job is done. Did I say that this was important? I cannot emphasize enough how important this little part is.
The tip input shaft of the transmission rides on this bearing. If this part fails it can take out your clutch and tranny...... /rant
Regards
Jean Marc Chartier
Old 03-01-2008 | 12:40 PM
koreyw69's Avatar
yep sorry ill be more specific next time and hey the front shocks are out on it. like rusted through, which i heard is a common problem since its an age and eveyrthing but um. i plan on putting a 6 or 8'' lift soon. should i even get new shocks until then
Old 03-10-2008 | 09:34 PM
koreyw69's Avatar
so i just got my truck back from the shop today. $650 bucks. new slave cyl. hydraulic lines tranny fluid clutch fluid and i think thats it so for the labor i dont think to bad. he said clutch and flywheel looked great.
but when i shift if i let the clutch out to fast it jerks really hard so i have to slowly is this cause its got alot of pressure built up or should i take it back in and ask him whats up with it?
Quick Reply: Clutch Wont Disengage...HELPPP
