Transmission & Amateur Radio
Old 02-28-2008 | 12:01 AM
n6god's Avatar
I have a amateur radio unit in my f150.. My question is " if I use it, I can not be over 25 watts. If I do the transmission light comes on. the code I get is P0781 (1-2 Shift Error).. Also it is only when i'm done talking on the radio..
Steven, N6GOD
Old 02-28-2008 | 12:13 AM
joshmac4.6's Avatar
Steven, N6GOD
Sounds like some RFI, when the code comes up, does the trans actually exhibit a 1-2 shift error?
Old 02-28-2008 | 09:19 AM
fairlaner's Avatar
I once had a late 80's Chevy work truck with some kind of radio in it. When I keyed the mike, the speedo would drop to 0 ... if you had the cruise set, the throttle would open wide trying to get the truck back to the set speed!
Old 02-28-2008 | 09:32 AM
n6god's Avatar
The transmission does not shift bad at all..
Old 02-28-2008 | 02:22 PM
Years ago, I had a car with an aftermarket cruise control - whenever keying up my CB mike the cruise would disconnect.
You have a RF issue somewhere - either your radio itself is not shielded well or something is not right with your antenna system.
Old 02-29-2008 | 10:01 AM
fairlaner's Avatar
When I had my problem, our shop had just installed a 'foot meter' (accurately measures distance in feet/meters/miles while driving) to the electronic speedo. I took it back to the shop and they shielded the wires for this installation and the problem went away.
Old 02-29-2008 | 10:52 AM
Steven, N6GOD
I've got a 65 watt Yaesu FT-2800M... and I've operated at full TX for 2 minutes at a time and never had any problems on my '07.
What band are you using? My Yaesu is a 2 meter only...
By the way, nice meeting another HAM.
73's
Chuck, KC2QQR
Old 02-29-2008 | 07:19 PM
Pinhead-227's Avatar
If you're having RFI problems in your vehicle, you're probably not grounded well enough. You'll want to get 1/2" grounding straps and ground everything together. The bed, the gas tank, the transmission, engine... Everything that is metal should be grounded.
Old 03-01-2008 | 12:26 AM
n6god's Avatar
I have a Kenwood ts-480 5-100watts 6m-160m and a Alinco dr635 2m-70cm 5-50watts...
Old 03-01-2008 | 12:33 AM
Oh, wow... you got some NICE rigs.
Which radio makes the truck act funky? What frequency are you on?
Old 03-01-2008 | 06:00 PM
n6god's Avatar
it is ts-480 any thing overs 25watts, i just most use 10m, 20m, 40m & 80m.
Quick Reply: Transmission & Amateur Radio
