Oil Leak
Old 03-02-2008 | 01:22 PM
rockbreaker's Avatar
Oil Leak
It looks like my transmission lines to oil cooler have a slight leak on the compression fit rubber lines.My question is could i cut the rubber lines out flair the lines and use hydraulic hose with gear clamps.How much pressure is on these lines also its a 04 f150 lariat with a 5.4l.
Old 03-04-2008 | 08:15 PM
Bonusbuilt1950's Avatar
Yes you can, but those lines going to the cooler aren't that expensive thru your dealer. Give him your vin and he can look them up, usually have them overnight. We do this all the time for customers.
Barry
03 F-150 reg cab 4x4
( Ford parts man )
Old 03-04-2008 | 09:12 PM
Fifty150's Avatar
2004? Take it to the dealer. You're still under warranty.
Quick Reply: Oil Leak
