weird problem...anyone else know about this?
Old 04-07-2008 | 09:24 PM
faulkincanyon's Avatar
Ive got an 02' 4.2 v6 and today I got in my truck and started driving...went to stop and had to put it in reverse for park..and I now have to drive on the 2nd gear for normal drive...and neutral is reverse...just had it flushed about 2 weeks ago..it shift fine...its just not matching up on the dash..anyone know what causes this??
Old 04-07-2008 | 09:45 PM
anyone?
Old 04-07-2008 | 11:06 PM
I think you need to wait longer than 20 minutes for a reply, this place ain't a chat room.
I've heard about this issue before, you might want to search through some older threads if you can't wait for an answer.
Old 04-08-2008 | 11:53 AM
sorry thread police
Old 04-08-2008 | 12:17 PM
05supercrew's Avatar
Your shift cable need to be adjusted at the tranny, very easy to do.
Old 04-09-2008 | 09:30 PM
JMC's Avatar
JMC
There is an adjuster wheel at the column. You need to remove the upper instrument panel steering column cover. That is the cover that is shaped like a big upside down U. If you look past the 4 way flasher button you will see some rubber and the cover. Place the shift lever in 1 and pull the cover to unclip it. Under this panel you will find the adjuster wheel. Place the shift lever in D and center the indicator using the wheel. They say to hang a 3 lbs weight on the shift lever but you can just pull it straight down. Do not pull it towards you or it will move into 2 or 1.
Regards
Jean Marc Chartier
Quick Reply: weird problem...anyone else know about this?
