Transmission fluid metering valve?
Old 05-21-2008 | 06:59 PM
BlueOvalFitter's Avatar
Question Transmission fluid metering valve?
2007 F150,4.2V6,4R75E transmission
Today I was looking at the underneath of my truck and noticed a block valve,5/8" thick,3" high,2.5" wide,near the center of the oil pan,with the transmission lines entering it and leaving it.WTH is this?
Old 05-27-2008 | 05:44 PM
Exclamation
A Ford tech on another website answered my question; it is a thermal recirculation valve;it keeps the lube circuit in the transmission from starving!
Old 05-27-2008 | 08:44 PM
That is there when you shift from R to D and vice versa.
It keeps the pressures equalized as well.
Old 05-28-2008 | 07:50 AM
projectSHO89's Avatar
It is the thermostatic transmission cooler bypass valve. It is there to route fluid back to the transmission instead of the cooler when the fluid is cold.
Once the fluid warms up enough, it then routes the fluid to the cooler for cooling.
Those are some entertaining answers......
There was a discussion of this valve about two weeks ago in this forum. It's probably down a couple of pages by now.
Steve
Old 05-29-2008 | 08:33 AM
Darrin Burch's Avatar
Steve
Exactly.
I don't know where the heck the guy that he talked to got that other stuff.
Darrin
Old 05-29-2008 | 04:55 PM
Exclamation
Originally Posted by Darrin Burch
Exactly.
Darrin
I got it from a Ford tech at www.flatratetech.com
Old 05-29-2008 | 06:03 PM
Geez, and those guys want you to pay to use that site...
Steve
Quick Reply: Transmission fluid metering valve?
