C6 fluid change
Old 07-24-2009 | 03:16 PM
privymaster's Avatar
C6 fluid change
I am set on changing the fluid on my 71 C6. I have the change kit from autozone, but just want to make sure I remember how to do this right.
I plan to pump the oil out from the fill hole as much as I can, then drop the pan, also isn't there a bolt in the converter to drain that from the little inspection cover spot.
So am I forgetting anything??
Old 07-24-2009 | 03:28 PM
Also, is there an additive to put in to help the seals, it sat for many years. Thanks
Old 08-02-2009 | 01:07 PM
Try just the new fluid first - if it leaks, then try a bottle of Lucas tranny additive.
C6's prior to 1977 require Type F fluid, and you CANNOT use Mercon.
Quick Reply: C6 fluid change
