2006 F150 Tranny Issues
Old 08-03-2009 | 10:54 PM
dnkrm's Avatar
Hey, I have a 2006 F150 4x4 5.4 liter, 40K miles, hex code TEJF4E5. I added an edge programmer at the beginning of March. Immediately I was super impressed with the power and shifting. I sent it off to be upgraded to a gryphon in March with custom tunes. I run a 89 performance tune and I have been pretty happy with the power, not much different than the canned tune, but I have never been really happy with the shifting. It seems like the torque converter will lock up either too early or too late and I would get some strange shifting when passing. I was never super concerned about it but was trying to get a hold of PHP to talk it over.
Anyway, today things have gone down hill fast. I had not driven the truck much lately, we took it to the lake saturday and I thought it was acting up a little. Then today it was very strange, when I slow down for a corner it won't shift down correctly, as I go around the corner and attempt to accelerate it feels like a manual transmission in a high gear, if I get on the gas it will finally kick down hard and then continue shifting hard. When I have the cruise on and am pulling a hill the cruise will be set at 66 and it will slow down to as much as 62 and as I crest the hill it will overshoot to 72, all while never shifting, I have never had that before.
So, when I got home I switched it back to stock and went for a quick spin, the shifting at highway speed was back to normal, no 3-4 shift problems and the torque converter seemed normal, but I still had the downshifting problem where it feels like a manual in a higher gear after slowing for a corner. Any ideas what the problem is? thanks
Old 08-04-2009 | 08:52 AM
jdmorris76's Avatar
Mine seems to do that out of the blue, where you take off from a light slow or make a corner and then you jump into it and it doesn't down shift and when it does, it's like it jumps two gears and really takes off faster than what you intended.
Old 08-04-2009 | 06:17 PM
JD790's Avatar
I could be wrong - but I'm guessing when you reprogrammed back to stock by re-writing the pcm hopefully the KAM (keep alive memory) got wiped out but in case it didn't, you could always try disconnecting the negative battery cable for approx. 30 min. This will erase all module memories including the KAM. After it has been erased, as you drive the next couple of drive cycles the modules will actually 'learn' how you drive and figure out a shift strategy. Sometimes it's as easy as resetting the KAM but not always. Something free and easy to try to begin with anyways.
Quick Reply: 2006 F150 Tranny Issues
