03 4x4 not ingaging,how to change the CAD
I would recommend a shop manual for the specs and how to. In a nutshell: remove the passenger side halfshaft. Remove the 3 bolts holding the front axle in place and lower it so the axle tube on the passenger side clears its mount point. Remove the vacuum shift motor then the 4 bolts holding the tube in place. With the tub out of the way remove the shift fork and gears. Here is the latest info I have for the replacement kit; Revised fork kit - #F75Z-3N139-KT FORK.
