transmission
What do you mean it jumps into the gear? Is the shift very harsh? Does it flare up and then hit gear? Are you running a tranny cooler? If not then I highly suggest you get one. If it's just a harsh shift then it's possible one of the accumulator piston springs broke and is causing a firmer..yet harsher shift. If it's flaring then you might have something more serious..or it just needs new fluid. Marcon V and a tranny cooler are musts.
Seabass
Seabass
